Selam bu konuyu çoktan açmak istiyorum ama bi türlü fırsat olmadı. Mini Cooper S JCW 2006 da aldım fabrikadan (Almanyadan) JCW 210HP kitli olarak geldi ve büyük frenlerde JCW vardı. Garantsi biter bitmez ilk modifiyem ALTA JCW iç hava filitresi, RMW street egzantrik, injector ve yazılımdı. Sonra JCW kansnağı %15 çevirdim. Sonra yetmedi daha derine girdik
elımden geleni resimli olarak açıkladım umarım beğenirsiniz... Tum modifiye Manatar Garage da yapildi. Herkezden bi MAŞALLAH beklyorum.
Şuandaki detayli listem şu şekilde...
Engine:
RMW Big Valve Cylinder Head.
RMW Race Cam. (GrandAm).
RMW Race Long Headers (No Cat).
RMW 450cc Injectors.
RMW Meth Kit (Aquamist HFS-6 with 8 mm) .
RMW Crank Pulley %0.
RMW Oil Cooler Kit.
RMW Big Radiator.
RMW Tune. (Remote Tune)
OEM Rods.
OEM Bearings
CP Piston 77mm stock sizes.
Hush-power resonator.
JCW Exhaust
JCW GP Intercooler.
JCW Air Box (Flap deleted)
K&N JCW Filter Inside Box.
ALTA Inlet House Black.
ARP Head Studs.
NGK BKR8IX Spark Plug.
BSH Lower Engine Mount Street.V
M7 Oil Catch Can.
M7 82c Thermostat.
M45 Supercharger.
Craven Speed %17 Pulley.
Motul 300V Competition Oil 15W-50
Transmission:
Getrag 6-speed manual.
OS Giken STR Clutch.
OS Giken Flywheel.
OEM LSD.
Motul Gear 300 Oil 75W-90.
Handling:
JCW Strut Brace.
JCW Big Brake Kit.
Goodridge Brake Lines.
RMW Special Aluminum Light Wight Front Rotors.
KW Variant 3 Coilover.
KW Club Sport Springs.
KW Camber Plate.
H-Sport Control Arms.
H-Sport 19 mm Rear Sway Bar.
Cusco Carbon Rear Strut Brace.
Powerflex Rear Strut Top Bush.
OEM Strut Tower Support Rail Kit.
O.Z Ultraleggera Wheel 17x7 Graphite Silver.
Tire Bridgestone S-001 205/45/17.
Motul RBF 660 Brake Fluid.
Accessorize and Electronics:
JCW Carbon Mirror Caps.
JCW Carbon Hood Scope .
JCW Carbon Bag Handle.
JCW Carbon Alcantara Hand Brake.
JCW Alcantara Shift Boot.
JCW Alcantara Hand Brake Boot.
JCW Aero Grill.
JCW Spoke Steering Wheel.
GP Rear Bumper Trims.
GP Black Sticker Plate.
M7 Carbon Gear Knob.
M7 Carbon Air Plate Diverter Carbon Fiber.
Defi Advance BF Boost Gauge.
Defi Advance BF EGT Gauge.
Defi Advance BF Control Unit.
Innovate XD-16 Wideband.
Pro Shift Light.
ALTA Gauge Pods (2).
OEM Bluetooth Mobile Phone.
OEM Gauge Dual Pod.
OEM Volt and Aquamist Gauge.
OEM Ipod Interface.
OEM Aux Interface.
OEM Harman Kardon Speaker.
OEM Armset.
Scosche IFWA Ipod Touch Charge.
Dynamat Trunk.
Dynamat Speaker.
Dynamat Rear Seats.
Oddessy PC680 Lightweight Battery.
Reversing Tilt Mirror Module.
Thermo Sleeves for Wheel Pump.
İlerdeki planlarım olursa:
RMW 1.8L Stroker Kit
RMW Radiator Tank
OS Giken LSD
Powerflex Front Wishbone Rear Bush Set.
Powerflex Steering Rack Mount.
Defi Advance BF Oil Temp Gauge.
Defi Advance BF Oil Pressure Gauge.
Arabanin en guzel kareleri
RMW Silindir Kapga
RMW Race Dürüm
RMW Koları
CP Piston
Engine:
RMW Oil Cooler Kit.
RMW Big Radiator.
OEM Rods.
OEM Bearings
JCW Exhaust
JCW GP Intercooler.
ARP Head Studs.
M7 Oil Catch Can.
M7 82c Thermostat.
M45 Supercharger.
Transmission:
OS Giken Flywheel.
OEM LSD.
Handling:
JCW Strut Brace.
JCW Big Brake Kit.
KW Camber Plate.
JCW Aero Grill.
Pro Shift Light.
OEM Gauge Dual Pod.
OEM Ipod Interface.
OEM Aux Interface.
OEM Armset.
Dynamat Trunk.
Dynamat Speaker.
Dynamat Rear Seats.
RMW Radiator Tank
OS Giken LSD
RMW Silindir Kapga
RMW Race Dürüm
RMW Koları
CP Piston
