Mini advanced camera system
    MINI GELISMIS KAMERA SISTEMI
    299 EURO AVRUPA FIYATI
    Kamera hareket sensorlu ve kaza durumlarinda kayit edip olay klasorune atiyor, on ve arka kamera olarak mevcut ikisi de beraber kayit ediyor.
    http://www.etk.cc/bmw/EN/search/sele...YS/66/66_0376/
    Once the vehicle jerks, start the camera recording and documenting as possible accidents or (attempted) burglary in the vehicle. Longitudinal and lateral acceleration are also recorded. Light-sensitive sensors provide excellent recordings, both day and night.
    The MINI Advanced Car eye can universally be used in virtually all MINI models.
    -The Very sensitive HD camera automatically detects critical situations that are relevant to the collection of evidence. The detailed video is also stored automatically.
    -by Various sensors of the light-sensitive camera and excellent signal processing are the shots with the camera day and night of excellent quality.
    -With The highly sensitive GPS receiver is an accurate record of the distance traveled and the driving speed.
    -Parkeermodus: When the vehicle was geperkeerd and movements in the video image or shocks are registered, is automatically recorded a video before and after the event.
    -The Videos are stored in an event folder, so there simply to events can be searched. The large display provides optimum readability.
    -The MINI Advanced Car eye is optically excellent integrated into the vehicle. The clearly visible buttons the operation is simple.
    -Standby: The display darkens automatically, so the driver does not get blinded when driving. Moreover, saving up energy. By touching the screen, this lighter.
    -The MINI Advanced Car Eye is also optionally available with Rear Camera.
    prices:
    € 299 Front & Rear Camera (without placement)
    € 265 camera just in front (without installation)
    € 90 Camera rear only (without placement, front camera also required)
    Detailed information:
    Scope of supply:
    - Windshield Camera
    - Cable for fixed installation (system voltage)
    - Camera to reach behind car with 6m cable
    - GPS module
    - 16GB SD Card, Class 10 MLC
    - Micro SD USB adapter
    - Additional adhesive pad for windscreen and rear camera
    - Instructions for use
    Refer to the EPC for the composition of the set.
    Technical information:
    - FHD (1,920 x 1080) progressive scan @ 30fps
    - Sensor 2.4M pixel 1 / 2.9 "
    - Pixel Dimensions: 2.8 x 2.8 x 1,911mV (LUX-Sec)
    - V cover 1.7; 120 ° field of view; 6-way glass lens
    - Lens Holder of zinc
    - Coretex A8 CPU @ 800MHz
    - Memory DDR2 256MB
    - LCD display, touch panel
    - Power supply DC 12 V; Super-Cap 3,5F, 5,4V
    (UPS)
    - Operating Temperature: -40 ° C to +80 ° C
    - Storage temperature: -30 ° C to +80 ° C
    Selling points / benefits
    - Maintains in critical situations the overview: The very
    situations that may be relevant in the collection
    of proof. The detailed video is also
    automatically saved. The MINI Advanced Car Eye is so
    always a reliable witness.
    - Improved security: The simultaneous gaze backwards
    by the inclusion of the rear view, makes a
    improved assessment of the traffic situation. the
    Safety is also increasing.
    - On the home screen, it is MINI split screen
    displayed. Here we see both the images
    windscreen camera and the rear camera.
    - Due to various sensors of the light-sensitive camera, and
    the excellent signal processing are the recordings
    the camera day and night high
    quality. The driver has an optimal view, even
    when it is dark.
    - With the highly sensitive GPS receiver is accurate
    registration of the distance traveled and the driven
    speed.
    - Park Mode: When the vehicle was parked
    and movements are on the video image or shock
    registered, a video is automatically
    and recorded after the event. The vehicle can
    guarded, without being there in person.
    - Maintaining overview: The recorded videos
    stored in an event-map, so easy to
    ensures optimum readability.
    - Attractive design: Light, bright and very
    quality corpus is designed in anthracite metallic.
    The shiny chrome ring around the
    lens harmony with the aluminum casing
    of the lens fitting. The MINI logo and the inscription
    on the windscreen camera and the MINI logo on the
    reversing camera accentuate the high quality of
    the camera. The design of the MINI Advanced Car Eye
    stands out so clearly from the outdoor optics
    FUN-cameras.
    - Easy to operate: The MINI Advanced Car Eye is
    optically excellently integrated in the vehicle. thanks To
    the clearly visible buttons, the operation simple.
    The menu is very intuitive and simple design, which
    operation of the camera makes it very user-friendly.
    - Standby: The display automatically darkens, making
    Moreover, saving up energy. By the display
    touching it is lighter.
    - The MINI Advanced Car Eye is as complete package
    and without reversing camera (for example,
    use in convertibles) are available, but there is also an a
    loose windscreen camera (as a replacement after eg. an accident)
    readily available.
    - Despite the stable mounting of the camera
    this at the same time be easily out of the container
    taken. Because the teeth engage in each other, the can
    angle can be precisely determined and put the container is individually
    applicable.
    - Easy mounting: The holder shall
    double-sided tape easily to the windshield
    stuck. The camera can be without visible cable
    mounted.
    functionality
    - Motion: The MINI Advanced Car Eye camera
    is automatically activated by shock
    increases only in those situations where there is a question of
    is event. The videos are in a special folder, the
    so-called "event-folder" saved. events
    can be reconstructed by simply as
    open folder.
    - Recording: The camera features a micro-SD card.
    Downloading videos to the PC without
    possible problems. The adapter for USB is
    included.
    - The software for the MINI Advanced Car Eye camera
    conveniently on the Internet at www.miniadvancedcareye.com
    be downloaded. The camera can also without
    additional software can be used.
    Compared with the competition
    - The automatic recording of videos at movements
    the video image or shocks during the parking mode
    New features, which form a unique advantage of the
    MINI Advanced Car Eye camera.
    - The design of the MINI Advanced Car Eye camera
    clearly distinguishes itself from competitors. the
    quality finish and the specially selected
    materials emphasize the high demands placed on the product
    be asked.
    - The large display and simple controls are still
    an advantage of the MINI Advanced Car Eye camera.
    - With a very fast memory allows multiple
    Videos are recorded. This is an obvious advantage
    relative to other camera systems.
    Bu kamera kullanildiginda, sigortada kasko yaptirirken indirim alinabikiyor diye duydum. Ancak gercekligini bilgili arkadaslardan ogrenebiliriz
      Ne yazik ki Turkiyedeki sigorta sisteminde oyle bir indirim yer almiyor.
      Bu arada yeni sponsorumuz bu konuda bilgi verecek deyip buradan isaretini de veriyim P
